Monitor connections
27 Feb 2010
Hey
Looking at getting a 5870.
If i want to connect 3 monitors via both the DVI connections and the hdmi port will it work straight out of the box or will i need some extra cables?
Thanks
Would'nt mind waiting for a 69** card but i can see the 6970 being out of my 300 budget.
This is purely speculative, but the 6950 should be faster than the current 68xx cards and I would guess, to be under £300 - probably closer to £250 I reckon.
No idea about your monitor question though, as does everyone else who have posted so far :)
Alright thanks.
Will take a look at a 6870.
If you don't mind waiting, then there will be a 69** card that is well within your £300 budget. In fact, their fastest single GPU 69** should be below £300 to make room for the 2 rumoured Dual GPU cards.
