Hi there
Here is an incredible deal from HannsG, basically its a slightly smaller version of their famour 28" model but at nearly half the price, yet its clearly not half the size.
Hanns.G HH251DPB 25" Widescreen LCD Monitor - Black @ £129.24 inc VAT
Encased in an outer frame of a high gloss finish, the exquisite arc contours further accentuates the monitor's subtle brilliance. Instead of a dull, traditional-styled stand, the monitor is supported by an exquisitely designed base with mild contours. The monitor stand is easily installed without any tools; you may also wish to wall-mount it for unparalleled versatility in space utilization.
- Screen Size: 25" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 15000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D
- Dimensions: 582mm x 422mm x 179mm
- Weight: 5.7kg
- Warranty: 3 Years On-Site
Only £129.24 inc VAT.
ORDER NOW
- Weight: 5.7kg
ORDER NOW
