I've been using a 20" 4:3 Viewsonic VP201b for the last year or so (no complaints) but the time has come to go dual monitor.
I could get the latest Viewsonic (VP2030b) which physically seems to match my current monitor but uses an updated panel. I guess these would look best side by side. Cost around £400.
The Dell 2407 looks tempting and the resolution, widescreen aspect and it's connectivity are very appealing. Cost around £620
The Samsung 244T is also on my list although it's more expensive but appears to use the same panel as the Dell. Reviews seem to indicate that the picture is superior though. Cost around £740 - Ouch !
My concerns are,
1. Is Win XP happy driving different resolution monitors? Is Ultramon the answer if there are problems? Anything I should be aware of ?
2. Slight niggles with the Dell 2407. I realise the A02 revision is an improvement but are there still issues? Really ? I can be quite fussy and will pay the extra for the Samsung rather than feel disappointed with the Dell. Hope that didn't sound too snobby.
I suspect in reality I would be delighted with the Dell but there's still an element of doubt.
I'm sure there were more questions but can't remember them now.
Any input appreciated.
My concerns are,
The A01 and onwards versions have a firmware fix which disables the Faroudja Video Processing suite (which Dell identified as the culprit here) in the "desktop" preset mode and so using that should all but eliminate any banding issues anyway.
