Hi Everybody
I have just aquired a AOC 2250swda monitor, the image is crisp and bright, so good it makes my older Samsung 203bw look yellow next to it which means I may need two eventually. The problem is the veiwing angle, its really bad if i move my head up or down 2-3 inches the image goes lighter or darker. I know the limitations of these panels but the older samsung is far better as is the even older Iiyama 17 inch i have which must be 5 years old now. I can move up or down at least 3 times the amount with the older ones with no real change.
It came with no dead pixels, so I can either put up with it or return it and try one of these.
http://www.overclockers.co.uk/showproduct.php?prodid=MO-085-IY
Can anyone tell me if this is a good one, money is very tight which is why I tried the AOC so I would value your opinions please as I have till Tues to let them know of a return. I use it mainly for Eve online W.O.T and watching the occasional films and surfing.
Thanks
Mark
Thanks
Mark
