OK Ive currently got a OCUK 24" 1920 * 1200 monitor (one of many who got one in this thread) but now it has begun playing up.
it doesn't come on when you turn on the computer on, it will display the the red box that normally says "no connection" for half a second then it goes blank, it repeats this for about an hour then eventually springs into life and works fine as long as you don't let it go into sleep mode or any other mode that turns of the monitor.
So obviously it looks like it needs replacing, but the issue come to with what.
Now only a couple of weeks back my wifes 19" OCUK 1680 *1050 monitor packed up but that one fortunately was under warranty, anyway Ive replaced it while we wait for DGM to fix it with a nice cheap one of these and while the wife is over the moon with her upgrade and my son (hes on a 17" 1280 * 1024) is looking forward to getting the 1680 *1050 for himself when it comes back fixed.
So I would like to replace it with something of at least the same resolution, but 1080 seems to be all the rage, and now everybody says how good 120Hz is. Of course 1920 *1200 monitors don't come cheap, so looking in that price bracket Ive got it down to a short list of these.
Dell UltraSharp U2412M 24" Widescreen LED Monitor - Midnight Grey [U2412M] £239.99 inc VAT
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black [HZ281HPB] £199.99 inc VAT
Samsung S23A700D 23" 120Hz 3D Widescreen Gaming Monitor - Black [LS23A700DS/EN] £203.99 inc VAT
or of course just to keep the missus happy one of these
OcUK 2436VWA 24" Widescreen LCD Monitor - Black [2436Vwa] £113.99 inc VAT
the rest of my machine is
Intel i7 920@4GHz
8GB ram
Nvidia GTX 470@800Mhz
Intel 80Gb SSD
Games I'm currently playing.
WOW
Diablo 3
I don't really play any FPS anymore although I used too and I'm sure I would again if the right one came along, I am normally happy with cranking the details up as long as I keep the frame rates above 40 fps, and using Vsync to keep the 470 from working too hard to keep the noise and temps down. So at 120Hz the 470 would be working harder in low intensity scenes (not capped at 60fps) therefore increasing noise and temps. I'm not really fussed about 3d, as I'm a glasses wearer anyway and wearing two sets of specs just seems odd.
hopefully this has made some sort of sense and somebody out there will come up with a good reason to go for one monitor over the others, there are no other upgrades on the horizon for the foreseeable future.
Intel i7 920@4GHz
8GB ram
Intel 80Gb SSD
WOW
Diablo 3
