Monitor for a 10 year old? (360/PC use)
5 Mar 2007
Macclesfield
I’m after a Monitor (or a HDTV) mainly for 360 use, although a PC may go through it in the future, due to the 360 I’m assuming one with a HDMI would be best? I’d like to keep the budget as low as possible (it’s for a 10year old so doesn’t need to be the best in class etc.) Anything above 20” will be big enough.
I’m tempted to for the Iiyama ProLite E2409HDS 24" (below) as its the cheapest I can see with a HDMI, any reason not to go for it?
http://www.overclockers.co.uk/showproduct.php?prodid=MO-067-IY&groupid=17&catid=510&subcat=
Cheers
FYI
You don't need one with an HDMI input to get it to work on your Xbox. There are plenty of tutorials on youtube showing you what you need to do. You just need a HDMI to DVI adapter.
FYI
Didn't know that, i'll look into later, i assume the same tutorials cover sound?
Cheers
alternative is good as the HDMI Monitors are seem little expensive for a 10 year old...
I might still get one, but the option is good to have.
Thanks
