I didn't pull the BX2450 recommendation out of thin air. It offers superior build and image quality to the P2450H. It used to cost £240 which was significantly more than the P2450H's £170 at the time. Now the prices are more in line the BX2450 is a wiser choice. It is still marginally more expensive than the P2450H but for the difference in quality it is more than worth it. They are both good choices though so don't feel hard done by if you prefer the P2450H's looks and want to go for that instead.
I have read your review of the BX2350 (which I appreciate), but the Cnet reviews had a couple of negatives about it, except the OSD:
"...very noticeable backlight clouding, low vibrancy in games,"
"we still recommend the PX2370 overall, thanks to its lack of backlight clouding and better designed OSD array."
Blacklight clouding... well do you feel that it is low enough it's not noticeable in normal use? It doesn't sound like a small problem in the CNET review though.
Low vibrancy in games is probably not only a bad thing - as they wrote it's because it has more accurate colors
Well, the PX and the BX can battle it out, but about the XL 2370 the only negatives, as CNET sees it, is its lack of ergonomic features and its wobbly base.
Also if you look at the contrast levels in your review on it, it seems a lot better than the BX...
