Hi all
Current rig:
AMD 7 3700x CPU
Titan Xp GPU
16GB 3600 Ryzen DDR4 RAM
Dell SG
I work in IT and during the day so lots of white and black screens with plenty of Googling and IDEs
My monitor is connected to my 2019 MacBook Pro via HDMI and I switch to DisplayPort when I switch to my main rig. I could run my laptop via USB-C if the monitor supported it.
I like the monitor size, resolution and refresh rate. I don’t like the colour accuracy, contrast and viewing angles.
For the past couple years this setup has been fine, however the time has come to upgrade to a more suitable monitor.
I’m pretty set on a 27” IPS QHD preferably with G-Sync or FreeSync2 (which I believe should provide adaptive sync with my GPU?) but I could go for a widescreen.
Budget £500 or so. Ive found this monitor which looks great:https://www.overclockers.co.uk/asus...c-widesreen-led-gaming-monitor-mo-0a2-as.html
Does anybody have any recommendations, please?
Cheers!
Current rig:
AMD 7 3700x CPU
Titan Xp GPU
Dell SG
My monitor is connected to my 2019 MacBook Pro via HDMI and I switch to DisplayPort when I switch to my main rig. I could run my laptop via USB-C if the monitor supported it.I like the monitor size, resolution and refresh rate. I don’t like the colour accuracy, contrast and viewing angles.
Cheers!
