29 Sep 2014 at 09:43 #1 Josu Josu Associate Joined 28 Jul 2014 Posts 273 Any advice please?) Not asus, this monitor to expensive and i cant have good fps in games which dont support SLI
29 Sep 2014 at 09:56 #2 Panos Panos Soldato Joined 22 Nov 2009 Posts 13,253 Location Under the hot sun. If you cannot get good FPS on 2560x1440 then the next down is 1080p.
29 Sep 2014 at 10:03 #3 Josu Josu Associate OP Joined 28 Jul 2014 Posts 273 Yes, i know it)) but i dont know which monitor))
29 Sep 2014 at 10:52 #4 SoulWings SoulWings Associate Joined 22 Dec 2012 Posts 126 Depends on your needs, do you want an IPS, or a TN panel?
29 Sep 2014 at 11:02 #5 Josu Josu Associate OP Joined 28 Jul 2014 Posts 273 I think TN... for gaming tn better
29 Sep 2014 at 11:04 #6 pgi947 pgi947 Soldato Joined 25 Jun 2011 Posts 16,800 Location Aberdeen Acer 27" 1080p gsync or for less screen the aoc 24" 1080p gsync. Either way you should be looking at gsync IMO.
29 Sep 2014 at 11:13 #7 Josu Josu Associate OP Joined 28 Jul 2014 Posts 273 yes... i am looking at this two... but i dont know... now i have cheap AOC , its allright i dont anything about acer
29 Sep 2014 at 13:10 #9 pgi947 pgi947 Soldato Joined 25 Jun 2011 Posts 16,800 Location Aberdeen Personally I would go with the Acer, they have a good rep and you're getting more screen for your money.
29 Sep 2014 at 13:42 #11 pgi947 pgi947 Soldato Joined 25 Jun 2011 Posts 16,800 Location Aberdeen Good stuff, iirc stock is due either the end of this or next week too
1 Oct 2014 at 09:14 #12 Josu Josu Associate OP Joined 28 Jul 2014 Posts 273 You joking??????????????? Again delay???????
