Monitor for Macbook 13-inch Early 2015
PPK
PPK
20 Apr 2018
Hi All,
Hoping some of you can help me as I am so confused. I currently have an early 2015 13-inch macbook with 2 mini displayports and 1 hdmi. I'm in need of an external monitor or two as I find the screen size hard to work with when working from home. I don't play any games and mostly use ms office, browsing etc at the moment. I'm planning to do some photo/video editing at some point therefore would like to setup for that. Also thinking of trading at some point hence the second screen consideration.
Connections: From what I've read, I need 2 x mini DP to DP cables to get the best resolution. Wouldn't mind usb C in case I upgrade the laptop and wish to minimise the number of cables i.e. charge the laptop from the screen.
Size: I currently use 2 x 22 inch at work which is great however find myself needing a third due to the number of windows I have open but I doubt I'd need a third at home. I was thinking of 2 x 27 but have also been considering 2 x 29/32/34. My new home office desk can be up to 2m wide so I do have the space.
Budget: Ideally don't want to spend anymore than £500-600 for both if possible.
Resolution: According to apple, the model can support up to 3840 by 2160 pixels on up to two external displays, both at millions of colors.
Thanks in advance for your recommendations.
P.
