Monitor for PC + 360 with Audio
22 Dec 2002
Teesside, UK
Hi,
I'm after a 22" ish monitor where I can use it for both PC and Xbox. Ideally it will have built in speakers that both devices can use somehow. Is this even possible without fiddling with connections each time.
So I was thinking
PC - DVI with the standard stereo cable connecting to the monitor
XBox - HDMI which can also carry the audio
Budget is £150. Can anyone recommend a suitable model
You best bet is to get a monitor with two HDMI inputs and a 3.5mm stereo audio output. Something like the Samsung BX2250 can do this - though it is over budget.
I wouldn't recommend getting a monitor with integrated speakers - as they are almost always terrible. Instead, connection a cheap set of 2.1 speakers into the 3.5mm stereo port on the monitor will give much better sound quality.
