Monitor for PC and PS4 PRO
23 Jan 2018
Hi all, after some advice.
I currently have the following:
https://www.google.co.uk/amp/s/www.overclockers.co.uk/asus-vx229h-22-1920x1080-ips-widescreen-led-multimedia-monitor-black-mo-067-as.html?template=ampASUS VX229H 22" 1920X1080 IPS WIDESCREEN LED MULTIMEDIA MONITOR.
I am think changing to one with the following specs:
    • 28-inch 4K UHD (3840x2160) monitor for photo-realistic visuals
    • Lightning-fast 1 ms rapid response time and Adaptive-Sync technology for smooth and fast gaming visuals
    • Displayport 1.2, HDMI (v 2.0) for 4K UHD playback; two USB 3.0 ports for quick-charging to your mobile devices
    • ASUS Ultra-Low Blue Light, Flicker-Free, GamePlus and GameVisual technologies provide tactical assistance on your command
Have been reading reviews etc and for my price range this seems the best for the PS4 PRO, which I mainly game on, also use my pc for office work and some gaming (PUBG etc) my question is, will I notice much difference in picture quality etc, specifically for the ps4 pro...
I'd say the PS4 Pro @1080p would be a bit pixelated on that monitor due to the down scaling. I used to have a PS4 Pro but had to use a second monitor for that reason.
If it doesn't bother you to much then go for it as when the game is in motion you would probably not notice much difference. If you game more on the PS4 then go for a 24-27" @ 1080p monitor. If you more of a PC gamer then go for it.
Don't get where you got 1080p from as he's looking at a 4k monitor?
Unless I'm missing something?
