Monitor for Photo Editing
3 Sep 2003
Looking for suggestions for a replacement monitor for photo editing. I currently have a Dell 20" 2007WFP. Very occasionally the backlight starts to flicker, which suggests replacement sooner rather than later!
I won't be gaming on the monitor, any suggestions for around £250 max? Preferably less. Ideally I want something around 24 - 27", I take it i'd be best going for something with 1440p resolution rather than 1080? Much as I'd love a twin screen setup, there isn't enough room for such a setup.
With regards to colour reproduction will I be best going for am IPS panel type, or a VA panel type? I know TN panels have very poor viewing angles.
Thanks in advance
Reviews are pretty solid:
http://www.tftcentral.co.uk/reviews/dell_u2515h.htm
Might be something newer out there nowadays, not looked much this year.
Reading that review, I think I may have hit a stumbling block already. My system uses onboard graphics (AMD A8-6600K APU with Radeon(tm) HD Graphics), with only an HDMI / DVI / VGA Dsub connection available... No DisplayPort! However I had been thinking about adding a discrete graphics card to the system, for better performance, so something I'll need to bear in mind...
The U2515H will take an HDMI input. You’d have to check what version your mobo supports but I suspect it’ll be HDMI 1.4 which supports 1440P 60hz.
Sadly the specs for my motherboard (Asus A88XM-A) state this:
Integrated AMD Radeon™ R/HD8000/HD7000 Series Graphics in the A-Series APU
Multi-VGA output support : HDMI/DVI/RGB ports
- Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 1920 x 1200 @ 60 Hz*1
- Supports DVI with max. resolution 2560 x 1600 @ 60 Hz
- Supports RGB with max. resolution 1920 x 1600 @ 60 Hz
Maximum shared memory of 2048 MB
AMD® Dual Graphics technology support *2
So a discrete graphics card may well be on the agenda first.
