I need a new monitor to go with my Surface Pro 4, my old monitor will look awful compared to the screen on the Surface. What would you recommend? I have put my main gaming PC behind the TV, switched on steam big picture mode and basically turned it into a (rather powerful) console, however I will be using this monitor to stream games from both the PC and Xbox, I'll also be using using it for web browsing, maybe some Netflix etc but not often and (yawn) work. Don't really want to spend more than £300 if possible, would like 27" but if that's not practical will settle for less.
