As the title says.
I’ve had to send my monitor away for repair or a new one if it can’t be fixed, so I’ve had to plug in an old hp pavilion 23xi to keep me going until it’s sorted.
It’s been working fine for the last couple days until earlier. I realised the mic for my headset was making a super loud crackling sound whenever I spoke, and It was doing it with 2 different headsets so I guessed it was the actual pc that was the problem.
All I’ve done to the pc itself is turn it off and unplug everything, then give the HD audio cable a look over.
Now anytime I turn the pc on it will turn the monitor on but straight away go back to sleep? When I unplug the HDMI from the back of the pc the monitor will turn back on?
Any help appreciated because the monitor is about half an hour away to getting a new fist sized hole feature.
