Monitor & GPU 4k or 5k
2 Jan 2005
Not been on the forums for a while so a little out of touch with hardware at the moment.
I'm looking to upgrade my monitor and thinking of either Dell P2715Q or Dell UP2715K.
Now I know I am going to have to upgrade my GPU but with new cards on the horizon with DP1.4 I may just go for a cheaper option for now until the new ones are available. I currently have Radeon 5800 series
If I go 4k I'm sure many cards have a single DP1.2 output, would prefer AMD as slighltly cheaper and do not use for gaming that often.
But with 5K are there any cards available with 2 x DP1.2 ports?
If not could I use 2 x GPU's each with 1 x DP1.2 port ?
What would be the cheapest option as a temporary measure for either the 4k or the 5k monitor?
Appreciate any advice:D
5k monitor is pointless at the moment for gaming as no single GPU would provide you with a decent gaming experience.
But could run the 5k monitor at lower resolution. Not really looking to do intense gaming but would be nice to have the extra screen real estate ;)
Does anyone know when monitors with DP1.4 ports will be available? Is it worth waiting it out for now?
I'm just so impatient :D
