Monitor Help
4 Jul 2008
UK - Maidenhead
Hi Guys,
I'm mid way through (finally) building a new pc. Spec below.. Can you guys recommend me the best way to go with my monitor(s)
Will be used for gaming/work/films etc.
Not sure if best used going for 2-3x 24" or 1x 27"-29"
Not set on a budget as yet, as little as possible but want to do my new machine proud.
i7 4770k (not yet overclocked), 8Gb Ram, Sapphire HD 7970 OC BOOST.
Any helpful advice is welcomed.
Thanks in advance.
