Monitor in the msi motherboard
7 Dec 2022
Argentina
Hello everyone, does anyone know how (if it is possible) to connect a second monitor in the msi A320M-A PRO MAX motherboard, cause i have been searching and there was no clue.
Thank you
The manual doesn't say how many monitors it supports (at least, not that I can see), but in theory an APU can support the use of both outputs.
The DVI-D appears to be only single link (max: 1920 x 1200 @ 60 Hz) and the HDMI is 1.4, which can only do 4K at 30 Hz.
Are you having trouble getting the second monitor to work?
As above, as long as the APU can support it, it should work. A quick search there doesn't seem to be a limitation for A320 based boards so give it a go and see what happens.
