- 27 Sep 2020
I have a weird issue with my Samsung 1440p PC monitor in that it can sometimes take ages to switch inputs. Its connected to my PC with display port and I have never had any issues until I try to connect something to one of the other two HDMI ports.
I picked up an Xbox Series S as a second console and attached via HDMI, which works fine, but often when I try to switch back, it does not switch back to the display port straight away. I often have to switch the monitor display on and off.
Would appreciate any advice as to what the issue is. I dont have a spare display port cable handy to test the display port cable, but when only one thing is connected to the monitor it works ok...
Thanks
Thanks
