Monitor is going to sleep while in VR...
15 Apr 2009
Recently got a 3080ti, updated drivers of course but now my monitor is going to sleep whilst in VR, which continues to work fine on the HMD (Odyssey+ WMR).
I have to cycle inputs on monitor to get the signal back. Never had the problem before. I've searched for a setting to fix it but not found anything.
Has anyone experienced this or have a solution?
Power setting is 'Never' against related monitor/screen settings. Away from PC right now but can only think to try going in via device manager and checking power saving options on there...
Well, I checked all possible settings and all were as they should be - checked again and main monitor went to sleep/lost signal until I cycled the inputs.
However, I've updated graphics drivers to the very latest - thought I had the latest when I was at 466.63 - and installed another update for Windows 10 that also popped up and tried ACC with the new card - monitor stayed awake plus, with my old 60hz settings, I can now run ACC at solid 90fps with same settings plus a few improvements.
I'd pretty much written off ACC, so that was a nice surprise! Will have to try ETS2 at some time too, as that wasn't great even on my old 2080ti...
