Monitor Issues. Please help
21 Jun 2010
HI there
Seem to have developed an issue on my Monitor/Display
Monitor in question is the Acer Predator XG270HU 144Hz and AMD 3GB MSI R9 280X GPU using the Mini DP connection
All drivers up to date ect ect
Basically it has started to flicker and go black every now and then. The flickers is not the normal constant background flicker but more of a screen break up/white line type of flicker (if that makes sense).
Another symptom that may help you clever folk if that the sound/speaker crackles/pops when it does it?
It does not seem to do it all the time but it is quite frequent
Any help would be much appreciated
Disable hardware acceleration on your browser (even if you don't have any tabs open when it happens). Does it reduce the frequency?
