Hi there!
I've come to Overclockers in the hope I can solve what is a very annoying problem I started having yesterday. My specs are:
Processor:
Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Memory:
6142MB RAM
Hard Drive:
535 GB
Video Card:
ATI Radeon HD 4890 XT
Monitor:
HannsG HW191D
Operating System:
Windows Vista™ Home Premium x64
Motherboard:
Gigabyte GA-EX58-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
I play a few heavy graphic games for intense periods of time, to say the least. The monitor is second hand so much be getting on to about 2/3 years old now. I have had my graphics card for about a year now.
The problem I'm experiencing is a flickering of brightness on the screen - this happens briefly on startup as well if the PC has been on for a while. That said, when I start the PC up in the morning all seems to be normal until 20/30 mins in and the flickering begins slowly. It's not a constant thing but more of a random fluctuation which seems to intensify.
Graphics settings:
GPU Clock max setting
875 MHz
Memory Clock max setting
975 MHz
Fan
50%
When the problem is happening my GFX vitals are:
59 oC
Everything else appears to be the same as normal except that my fan speed seems to jump around a bit, having looked at the Catalyst Control Centre.
I'm thinking my most likely problem is that the monitor is getting too old now and the backlights are fading, something is overheating somewhere inside the monitor or there's a loose connection.
Any advice or speculation would be incredibly helpful so I can diagnose the problem and move on accordingly.
Thanks in advance!
AndrewHk2
Processor:
Memory:
6142MB RAM
Hard Drive:
535 GB
Video Card:
Monitor:
HannsG HW191D
Operating System:
Motherboard:
Graphics settings:
875 MHz
975 MHz
Fan
50%
59 oC
Thanks in advance!
AndrewHk2
