Monitor kept go blank
22 Mar 2009
When my pc is overclocked at 4.00GHz at 1.300v vcore and 1.640v dram and temperature is 79C after 2 hours linx testing with 100% passes 100 out of 100 and then few minutes later my monitor went blank and power off itself, as I had check my display and sleep is set it as OFF but the pc still running then after few minutes later, the pc restart itself.
The same problem ongoing since the bundles was brought from OCUK. After 2 hours the monitor went blank and pc restart itself.
Not very happy :(
