Monitor not displaying on PC start-up, sometimes!
29 May 2005
Lazenby near Redcar
I bought an Iiyama G-MASTER BLACK HAWK G2730HSU-B1 27" monitor in October. It is a nice little monitor with crisp clean display, I'm using it to work on 3D design for 3D printing. It is displaying from a Gigabyte RXT 2060 through the Display Port connection.
My normal practice when starting a PC is to first switch on the monitor then the PC however this does not work with this monitor. I have to switch on my PC, then switch the monitor on when the keyboard lights up and about seven times out of ten this works. When it doesn't I have to leave the PC to run for a while before powering it down by the On button. This is just a pain the the butt.
My thoughts are that the monitor is not staying live long enough to receive the Display Port signal. I am using a 3 metre cable, perhaps it's not fast enough (only joking).
I could change to the HDMI ports but would need to buy a cable.
Any help would be appreciated.
sculptor
Can't you just leave the monitor on all the time and let it go into standby on its own when you shut down your computer ?
This seems to be a fault with some iiyama monitors. They won't switch on after standby. They are supposed to. I would speak with whoever you bought it from and or contact iiyama.
