Monitor not switching on (R9 290)
17 Dec 2004
Is there a fix or work around for this problem yet, as sometimes when my r9 290 turns off the monitor, then when you move the mouse to turn it back on, it doesn't come on. The only way I have found to get it on again is putting it in and out of sleep?
I used to hit windows key+P then up arrow and enter, then down arrow and enter. It effectively switches it to your second monitor then back to your first one again, dunno why it works but its how i used to bring it back. Assuming your have 2 monitors connected :)
Mine isnt overclocked,, I had 2 monitors, but now only 1, enabling/disabling the second monitor worked.. are there any tools out there for turning off and on the primary monitor with a shortcut, as that might work?
