Monitor not working at 120hz?
8 Oct 2010
Purley - Croydon
Hi guys,
Not 100% sure whether it's a monitor, gfx card or other issue.
When using 120hz in the settings, my S27A950D goes fuzzy whereas the monitors eiher side of it (S27A750D's) work perfectly fine.
I've limited the only factor causing the fuzziness is anything above 60hz in the NV CP and BF3 CP.
Is there anything I could try to confirm if it's a monitor/something else's fault?
Thanks
Remind us how you have them connected up Cleeecooo. I am sure you had reported some issues earlier and said you tried swapping the connections around and one monitor was always having issues?
I don't recall those issues? (I've had so many issues since then :()
Both 750D's DP
950D DVI-D
My only issue that I can remember was the dead pixel?!
The current issues starts very spontaneously, it was working down for some time, then this just happened?!
I thought you were having some issues earlier on - maybe it was somebody else. That sounds strange indeed. Which GPUs are you currently using? I lose track of that one ;).
Would that happen if the cable or connections were being dodgy and not being capable of the > single link bandwidth requirements? Have other dual link dvi cables to try?
