Hello folks,
First of all, correct forum?
Last night was the first time I've experienced this annoyance in which my monitor doesn't turn on when my PC is booting up. The little box in the top left-hand corner that flickers 'Digital/Analog' appears followed by a floating box 'Check signal cable'. A simple push of the restart button did the trick and off I was to desktop heaven.
Now, tonight's problem... I came home and turned on my PC for a bit of RIFT, no monitor. Hit the restart button, no monitor. Rinse and repeat this for a couple (read 5 or 6) more times and eventually I saw my monitor come to life and ended up on the desktop, safe and sound.
DVI cables are securely in place, I'd end up shearing the screws if I tightened them any tighter.
I'm at a loss, if anybody could shine some light on this, it'd be much appreciated.
Cheers,
-Mikchi
Cheers,
-Mikchi
