- 7 Jul 2008
Hey
Does anyone know if the ps4 will be ok with a monitor on top of it?
It has a fairly small base roughly 6 inch diameter which would fit nicely on the matt side of the ps4.
The base of the monitor can get quite warm as this is where the a/c adapter and other ports are, and it's not too heavy for it either.
is the ps4 ok with heat?
Thanks
Thanks
