Monitor or Plasma Tv
15 Apr 2018
Hi all
Did not want this to be my 1st post, but its important.
Panasonic viera plasma 42 inch, would this be suitable for gaming on from a PC?
Tv is about 6 yrs old and its used for PS4 at the moment.
Looking at going PC but haven't the room for desk and LCD monitor etc
Many thanks
I think the downside to using TVs are the refresh rates are not as good as top end monitors.
Also would you not need a desk to sit in front of the monitor/tv if you are playing games that you will be using keyboard/mouse for?
Not sure what my refresh rates are on tv but its a good tv, what would you be looking at?
It for my 12 yr old, so would look at a gaming chair rocker type or beanbag and use a small table for mice etc, bit like a tray table that you could have breakfast in bed if you know what I mean.
cheers
Should be fine. I've got an HTPC which does a bit of light gaming plugged into my Panny Plasma in the living room. Just make sure to set the viewing mode to Game.
