Monitor/Pc cutting out
26 Sep 2013
Hello,
I have an issue that has only happened within the past couple of days, basically something cuts out and my monitor shows no signal so its like there's no wire connected, i have to then turn the PC on and off again and it will work fine for a little while but then will do the same thing again. has anyone got any ideas of what this is? i connect it to my monitor using a VGA cable.
Thanks
also it could just be the monitor and the drivers of the gpu or something if the intel apu works then update the monitor drivers to the latest version.
