monitor / pc problem
18 Oct 2002
last week for some reason if i switch the PC on i get no display on the monitor (it just switches to power saving mode).
The strange thing is that if i switch the pc etc off via the wall socket (or unplug it for 30 seconds). switch the pc & monitor on and it works fine.
i tested if the same thing happens with the 360 which is connected to the monitor and that worked ok.
I checked the cable from the pc to the monitor, etc check inside the case.
But ive no idea what could be causing it. It just seems strange that i have to switch off at the wall before the monitor gets a display from the pc.
Anyone know what could cause this or anything else i could check.
