Hi so i turned on my computer this morning started using it then after about 30 minutes the screen went black every thing in the background was still running fine i took the VGA cable out and plugged it back in the screen came back as normal but then after 5 seconds it goes black again it does this every time i take the VGA out and put it back in
I have tried two cables this happened with both so its not the cable
I have tried two computer's same problem so its not the computer
I am now using my TV monitor to type this
The monitor is about 6 years old now and iv never had this problem before
its a 19" Cibox
Model number: LW1922C
Is there any reason this could happen? If so is there a fix? Or is it time i got a new monitor?
Thank's for any help
its a 19" Cibox
