Monitor questions
15 Nov 2005
London
Just got a brand new Smasung 244t and it's great :D
Just a couple of questions I wanted to ask though.
I've got both DVI and VGA with this, which is better? I put in DVI, it didn't work. so I put in Analog and that did. I just realized though that was because I didn't change the source to DVI from the menu :p Is there any point in changing if this is wokring perfectly? what difference does it make?
Also, the cd that came along with it, which has a User's Guide, Natural Colour, Magic Tune, Magic Rotation and some drivers, doesn't work.
Do I really need the cd? or should I just forget about it?
If you have the option to use DVI then do so, the picture quality I find is far better than a D-Sub connection. Running a VGA connection to a flat panel requires a digital to analogue conversion in the PC followed by a conversion from analogue to digital conversion in the monitor. DVI is all digital so no losses due to unneccesary conversions
Thanks :) I switched to digital. I don't notice any difference, but hey, if its supposed to better, than good!
Anyone have any ideas about the cd?
I have two of the same monitors and I use one with DVI and one with VGA, I don't notice any difference in quality between the two (I used to with my old monitor that was on VGA).
I dont think there is any real need to use the CD..
