- 19 Feb 2011
Hiya guys im after some recommendations for a new monitor.
Its main use will be connected to my Xbox One X and my PC which is running a Vega 64, so is possible Freesync would be a must, it must support Freesync on both DP and HDMI though.
Not too worried about it being only 60hz as i will probably use a different resolution for the PC, probably 1440p so capping 60fps should be easily done.
Would like HDR and if possible proper HDR not that low end 400nits stuff
Screen size would prefer it to be 40"+
Anyone know of anything suitable or even use anything suitable?
Also if possible IPS would be best, but i know thats going to be a long shot.
