- 27 Oct 2005
Is this even possible nowadays? My home monitor just lost the bottom line of LEDs, so i turned it off and on and it is now just a black screen
It is 3 months out of warranty
((, I can still hear sound if use HDMI, the power is on but nothing onscreen.
If so does anyone know of any companies that do this? kind of work?
ta
tis this one :/
https://www.overclockers.co.uk/phil...led-monitor-black-3yr-warranty-mo-02b-ph.html
((, I can still hear sound if use HDMI, the power is on but nothing onscreen.If so does anyone know of any companies that do this? kind of work?
ta
tis this one :/
works 80% of the time. Not going to lie, Samsung done a really poor job on one of them which went back 3 times without a fix, I ended up soldering new caps in myself. Could it be worth finding out if you can strip it down and get a spare panel for it. It could also be an inverter board gone. If you look really closely can you make out a picture within the black screen?
