- 9 Nov 2012
Hi all,
I'm back in the UK now and left my two old Samsung monitors with a friend in Oz.
I'm looking at gradually upgrading my entire system (apart from the GFX card) as I have the itch. The main computer is currently sailing the oceans somewhere; but I'd like to have the monitor solution sorted for its arrival (plus I'm getting fed up of playing games on my laptop screen).
I'm thinking of going with a 3 monitor solution utilising at least 26 inch monitors at either 1080 or 1200 (one of my monitors was 1200, one was 1080). Firstly; is 1200 supported as a main resolution or is the 1080 image just stretched to suit?
I've not experienced 100+hz monitors; are they mainly of benefit to fps games or everything (including films etc)? I'm more of an MMO player but would like to get into race sims etc. Would a 100hz panel be worthwhile?
Suggestions for the best "gamer" monitor for this setup (normal and 100hz). I'd like as thin a bezel as possible.
I assume 4k is not really going to take off (from an economical point of view) for at least 3 years?
Cheers,
- Matt
Cheers,
- Matt
