Monitor Set-up
27 Sep 2012
I currently have 4 monitors, with 2 running off my gaming pc and 2 running off my work laptop. They are on two separate desks, but I would like to move them all to one work station.
The work monitors are both 32" Benq's and I have just bought an AW3225QF to run alongside an LG 27" on the gaming pc.
I have purchased a couple of monitor stands to try the LG above the AW, and they are either ridiculously fiddly, or I have no faith in them not collapsing. All options have been purchased from Mr Bezos and did not cost a huge amount.
I would like to have the two sets of monitors side-by-side, but I really need a good option for supporting them. I don't really want to drill anything into the walls, though I will if I can't find a secure desk clamp alternative.
Does anyone have any recommendations for either a set-up, or a stand/mount that I can use?
Edit - I should say the desk is up against a wall, so I can't have arms that offset the back of the desk as they need to be reasonably flush against the wall (hopefully that makes sense).
Are the OEM stands which came with the monitors of no use?
I use these from bezoland
ErGear Single Monitor Stand
They are freestanding and I've not had any issues.
I would like to stack them i.e. 2 banks of 2. I've seen some highly rated desk clamps for £140+ but I'm reluctant to purchase any of those without recommendations.
I use Hemudu Dual Monitor Stand - Vertical Stack. Has been working well with a 34' ultrawide and a 27' monitor above it
I got one of these earlier this week. All is ok with it so far but it doesn't seem to be the same quality as the Dell stands it replaced.
I use a hemudu dual stack one too,under £35 on the rainforest. I have the clamp variant.
I’ve got a 34 under a 28 on it and it holds them solidly.
I guess the adjustment and cable management is not as good as some of the pricier options but for the price I think it’s really good
I havent had any problems with mine once it was set up. I understand what you mean though
