monitor sharing, switch box problems
21 Jul 2005
hey guys, i recently purchased a switch box and relevant cables so i could use both my pc and my xbox 360 with my single monitor, i have run into a problem though, the xbox works fine but my pc display will only work up until the desktop gets loaded then it losses signal,
im running a 7800 gt with 2 dvi outputs and the switchbox has only vga connectors so ive had to convert a lot of cables, my monitor is a xerox XA7-192i and only has a dvi input cable,
any ideas guys?
thanks in advance
