Monitor stand or arm question
25 Nov 2011
The KOP
Guys is they any arms or stand for having two monitors one above the other?
I have 27" main display and a 24" second display.. Am moving to a full size tower case soon and plan on placing on my desk..
"See Image"
I would like the case where the 24" is and move the 24" above the monitor I have in front..
Is this possible?
Price range I feel less than £100 if possible.
Rain forest has Duronic DM35V2X1 holds 2x from 13-27" pole is 610mm = 61cm my 27" is 37cm and 24" is 34" = 71cm I guess this means I could only hold one 27" and something less than 24"
I'm sure I have seen mounts for two monitors one above the other, but how useful would a second screen be above a 27"?
Have you considered wall mounting the upper monitor?
Take a look at the Allcam mounts, They do a nice duel as gas strut type. Desk and wall mount, GSD240D is the desk one. They do other twin mounts but just check the weight of your monitors.
Others that do twins are Ergotron, but they are expensive. I have a single wall mount gas strut type to take the weight of my asus monitor(see link in sig).
Don't want to be drilling into wall. Tbh the monitor use is only for streaming reading chat, having other programs running, youtube, Facebook anything really.
Wow well done on that build.
Since posting this am now maybe looking to instead above, place the monitor on my left hand side. I seen 3 way stands that I can remove the right side so have my 27" still in the middle and have the 23" off to my side.
Need to work on how much it will hang over etc I don't want to going to far.
