Monitor Stands
Permabanned
8 Jun 2011
I'm looking to get my hands on a stand that will lift my monitor up to approximately the same height as my iMac that sits next to it. I'm quickly running out of desk space so would prefer something relatively small.
It's got to look smart so not interested in any of the £9.99 plastic tray things - ideally something metal would be good.
I've seen one of no competitor talk! but they look pretty big. Something similar would be ideal.
Here is my current set up.
I said it has to look neat!
I don't think I could ever get rid of my iMac... too loyal. Yes, I am one of those Apple followers...
move the apple further away?
optical illusions > paying for stands :)
You could get a peice of wood which matches the table at the correct height...or perhaps something glass. or maybe get a dual stand that could hold up both at same height? (remove stands etc)
That's a decent point actually. In an ideal world I'd have them both mounted on the wall - but I think the new iMac is a bit arsey about being mounted, from what I have heard.
Maybe I should explore mounting the PC monitor instead - that'd be ideal.
Stop antagonising the poor man. any single vesa stand you like the look of, plenty around...or a dual one if the apple has a vesa compatibility.
