Monitor suggestions
20 Feb 2019
Hi,
I'm after another monitor that would work/look good with a monitor I purchased from OC back in 2015,
- AOC G2460FQ 24" 1920x1080 TN Widescreen 144Hz 1ms Gaming LED Monitor
I currently have a dual setup but the other monitor is put it lightly rubbish.
Can anyone recommend an addtional monitor or would it be best to replace with 2 newer models?
Thanks
Setup
GTX 970
Intel i5 6600k
replace the lousy monitor with this one?
My basket at Overclockers UK:
Total: £409.28 (includes shipping: £9.30)
it's the newer version of the aoc that you have
but 24.5 inches rather than 24 inches
also has full freesync range (that should work with your gtx 970) 30-144hz with low framerate compensation [error]
then use your current g2460fq as your secondary monitor
(nvidia freesync only works on the primary monitor)
Is the GTX 900 series working with GSync compatibility now? Last I heard NVidia only made it available on the 1000/2000 series cards.
