monitor temps on amd 555be
HWMonitor should give you a temperature. CoreTemp will probably fail as the temp sensors don't work on unlocked chips.
Core temp read onboard sensors (inaccurate). Hw monitor read mobo sensors, which are the only accurate ones.
If those I'd be reverting to an ir gun (ir thermometer) which are ~£15 but be warned, if you do that you'll be reading the temp of everything in pc and anything that moves, like your foot or the cat :p
+1 :D
