Monitor/TV for gaming (55")
18 Oct 2011
Hi,
just wondering if anyone can point me in the right direction for gaming on a large monitor/tv, looking around 55inch. Basically for when i am laid in bed chilling (with controller) and wanting to play need for speed titles or some diablo 4 etc. Not sure on the best way to connect my PC to the TV/Monitor or what am i looking for. Cheers
You could consider:
LG OLED evo C3 55 inch 4K Smart TV 2023
LG OLED evo G3 55 inch 4K Smart TV 2023
Connect via HDMI.
You could consider:
Connect via HDMI.
Ohhh ok, thanks. I will take a look at those. Might be a stupid question but would the length of the hdmi cable matter. Would need a pretty long one
You can get relatively cheap passive HDMI 2.1 cables up to 5 meters and if you need it to be longer you will need something like fibre optic HDMI cable.
I’m using 20 meters fibre cable that supports up to 48Gbps and it works great (was under £40 on rainforest).
Seems like LG pretty much has the gaming TV market cornered. 4k high refresh rate and hdmi 2.1 are the features you're looking for
