Monitor upgrade from a Hazro.
21 Nov 2010
Hi all
Is there a better monitor out or coming than a Hazro 27C for visuals in games.
Must be same or higher res a 27-30inch £700 max.
Cheers
DX
Well I have used the Asus PB27Q and the Samsung S27B970D and love them both - especially for gamimg.
The downside is the Samsung is a little above your budget but the Asus is well within it.
Worth checking out the Dells as they seem to have a big following but I've never used them so can't comment.
You already have one of the better high-res large IPS displays for gaming due to low input lag and good pixel response. The only possible upgrade would be a 120hz display, but in many areas that would also be a downgrade.
I thought with all the new IPS panel tech there would have been a worth while upgrade thought I think I'll leave it for now.
Cheers
DX
