Monitor Upgrade Recommendations
19 Dec 2006
Saudi Arabia né Donegal
Hi All,
Considering an upgrade to my current Samsung SM206BW with a budget of £300.
I'm looking for something in a size 23-24" (1920x1080?) and I believe 120hz is the current next best thing.
Looking at the Benq 2420 which seems to tick all the boxes. Would this be the one to go for or is there a better monitor which I should consider in approximately the same price range?
Thanks in advance,
Antar.
I am extremely happy with my BenQ, can't fault it for gaming at all....it's great all round even with colours for a TN panel.The monitor adjusts very easy too and barely produces any heat.(mine feels constantly cold)The responsiveness/smoothness is hugely better than my old 60hz monitor and my gaming has improved.
If you are on Nvidia card go for the BenQ, if AMD then go for the Samsung 120hz models just incase you wish to try 3D sometime.
