Monitor Upgrade?
11 Apr 2003
Notts
Hey all, currently have 2x Belinea 1925S1W Monitors which I have had for the past 3 years, they are brilliant monitors and I have had no complaints about them.
I use my PC for some gaming, but mostly for 3D Modelling and the like, now I am tempted to get a slightly bigger monitor but really I have a few questions:
1) Is it actualy worth upgrading for an extra 3 - 4"?
2) What monitors would you suggest?
As I am getting to they need to be affordable so around £300. I also want to be able to use my 360 on them, if I dont have to plug it in each time that is a bonus.
Thanks all!
Jcb33.
Like you i'm also a graphic designer
I've been working on a 19inch and its just to small when i work in Zbrush, 3dsmax etc...
I just got the Dell 2209wa and waiting for it to arrive. I didnt get anything bigger then 22 inch because ill have the 19inch next to me so thats practical if your playing around with textures on the side or need some references
If you want a 22inch then get the Dell as its better for multimedia/design aka its no TN panel.
Any other suggestions? Quite like the look of Samsung monitors, But do not really want to pay more than my budget.
Jcb33.
Jcb33.
I have just ordered from a different site Asus W246H LCD monitor,its big at 24" WS with native 1920x1080 res so 16.9 screen,great for xbox,movies etc...Their homepage below,prices are anywhere from £200 to £260 , its TN panel with HDMI,VGA,DVI .
http://uk.asus.com/products.aspx?l1=10&l2=151
Currently lookin at the LG W2261V 22" , it would be aroun £330 for 2 of these, and it has HDMi and DVI, but is it any good?
Thanks Eleyon will check those out.
Jcb33.
