Monitor upgrade
9 May 2009
Kent
hi guys im looking for a monitor upgrade over my current one what can you reccomend? normal use and gaming are my requirements.
Currently using a Samsung syncmaster SA850T
Kinda depends on what you want. I'd say you'd want 144hz and that you don't want a TN panel. Also, do you want 1440p? Your gpu will struggle to push that resolution but you might be upgrading in the near future for all I know.
You could maybe look at a VA panel like this https://www.overclockers.co.uk/aoc-...-curved-widescreen-led-monitor-mo-04p-ao.html
VA, 144hz, 1080p which would be perfect for your gpu.
You'd have to go close to £400 to get 1440p with VA/IPS and 144hz.
