monitor upgrade?
23 Oct 2007
ilfracombe north devon
Hello everyone.
My question is= At the moment i have a BenqQ XL2420T 120 hz monitor.
I have a i7 8700k cpu + GTX 1070 gpu, would getting a Dell S2719DGF monitor be a good upgrade and would my cpu and gpu be good enough to run the monitor, i only use the monitor for gaming.
Thankyou very much any help would be great :)
Should be fine and a very decent upgrade, though your GPU may struggle to reach the higher refresh rates in modern titles without some big compromises on quality settings. Looks like the Dell has good GSync compatibility though, so that's a huge plus which will help out a great deal on that front.
Which games do you play? You should take a long look at the Acer Nitro 4k because you'll be able to play older games at 4k and at over 60 Hz.
i play fps = call of duty- black ops 4 -titanfall2
Don't know what monitor you have but if its an upgrade in size and resolution, Dell S2719DGF would be well worth the money. Seriously good monitor and ideal for these sorts of games.
Its very fast and looks great. Adaptive sync works really well, If you get one just make sure you have a Display port cable as it does not ship with one.
