- 21 Sep 2006
Hi all,
Can anyone help recommending a monitor with component-in, preferably without costing the earth?
Seen the Dell IPS and the Asus 23", but ideally under £200.
Problem is currently I have Pc using DVI, and PS3 using HDMI on my BenQ, but I also have a Hava to record output from my PS3. Hava input is component, so need to output to that from PS3. I did buy a component to RGB convertor box but the picture is just awful - I'd really like to get away from constant swapping of settings on the PS3.
Happy to go with just component output on the PS3, but have to get a new monitor so I don't need convertors. Another option would be sticking with HDMI (as I'm looking at replacing the Hava, maybe with the Black Magic) but would need a HDMI->HDMI HDCP stripper, which I can't find - all the HDFurys are HDMI->RGB etc.
Any advice appreciated.
Cheers
Cheers
Did consider the TV approach, but even then it's tough finding something 22-24" in that price range that will do 1080p.
