Monitor with no VESA mount
30 Dec 2012
Derby, UK
I have an Acer S240HLBID which has no VESA mount, so I was wondering if there was any way to mount it to a stand, or if there is nothing i can do.
thanks in advance :)
Well depends on how comfortable you are modding it but I had an old acer p series somthing and I opened it up to check the depth at the back found about 4mm free put a metal plate in and drilled mounts into it. Survived 2 years before power supply popped taking the monitor with it.
Short of that there are some monitor mounts that grip on the sides of monitors but they don't sell them here so can't link sorry. (No good for multi monitor setups as it increasing gap between bezels).
